timing
Old Apr 13, 2005 | 01:36 AM
skatepony's Avatar
skatepony
Default timing
after doing some major engine work my timing wont adjust.....the distrubitor never came out but whenever i try to adjust it no matter which way i move it the timing stays the same any ideas?
Old Apr 13, 2005 | 01:38 AM
bobby's Avatar
bobby
Default RE: timing
so you CAN move the distribuotr?
Old Apr 13, 2005 | 01:41 AM
birdman076's Avatar
birdman076
Default RE: timing
Did you pull the spout connector? You have to pull the spout when the engine is off, start it up, then set the timing and reinsert the spout connector.
Old Apr 13, 2005 | 10:59 AM
fats429's Avatar
fats429
Default RE: timing
[sm=icon_rtfm.gif]
eaven with the spout in you can change the base timeing on the engin it just wont be a accauret reading . it does change with the movement of the dizzy . thats how it works . did you lossen the clamp and turn the dizzy . Bull **** the engin will stall if you turnit to far , come on now stop post whoring
Old Apr 13, 2005 | 11:54 AM
86HOGT's Avatar
86HOGT
Default RE: timing
Easy fella...
Let's say that someone doesn't pull the SPOUT connector to adjust their timing. They turn the distributor but when they do, the computer wants to keep the timing at its prgrammed spot furing idle, so all the see at the light is hardly any movement.
Old Apr 13, 2005 | 10:28 PM
birdman076's Avatar
birdman076
Default RE: timing
Post whoring huh?? Well theres a correct way of doing things then theres the advice you gave lol. I suppose you time your car by ear as well? Try a timing light and a Ford Service Manual. And for the record it will stall if you retard the timing too much, but will rev up if you advance it flip side of the coin to everything. 86HOGT hit the nail on the head, the ECM will compensate for timing adjustments when the spout is in.
Old Apr 15, 2005 | 01:17 AM
silver91gt's Avatar
silver91gt
Default RE: timing
I adjust mine by taking the spout out when it is running, there is a slight idle drop, but it works.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
