Can I run my engine w/ the tranny out?
Old 04-01-2008, 11:32 AM
Beegle8950
Beegle8950's Avatar
Default Can I run my engine w/ the tranny out?
I had a small oil leak around my rear main seal and oil pan gasket, so I took the tranny out and attempted to seal the leak with some silicone (I know that’s not the best solution). I’m not even sure where the oil was coming from exactly, and who knows if or how long the silicone will hold, but would it be ok to run my engine while the transmission is out so I can check for leaks again? Will the motor mounts provide enough support?
Also, I found some oil around my PCV valve and in the vacuum hose that leads to it. How could oil be getting there?
Thanks!
Beegle8950 is offline
Old 04-01-2008, 12:27 PM
94Yellow50
94Yellow50's Avatar
Default RE: Can I run my engine w/ the tranny out?
well the starter bolts to the bellhousing so im not sure how ur planin on startin it...
94Yellow50 is offline
Old 04-01-2008, 03:06 PM
Beegle8950
Beegle8950's Avatar
I would bolt the flywheel and bellhousing back up without the clutch. Of course that's added weight on the back of the engine, so maybe I should try to support it with a jack or something? Although there may be too much vibration for that. I guess I'm looking for someone who has tried this without it ending badly before I make some kind of mistake.
Old 04-01-2008, 03:23 PM
r.barn
r.barn's Avatar
as long as clutch and shift fork are gone ,,,, sure
r.barn is offline
Old 04-01-2008, 03:58 PM
cody91mustanglx
cody91mustanglx's Avatar
i wouldnt start the engine without the tranny, but thats just mei had a buddy in thr past attempt with a jack and there was to much vibration
cody91mustanglx is offline
Old 04-01-2008, 05:43 PM
AdderMk2
Banned
AdderMk2's Avatar
the engine will not be stable due to the fact that the tranny mount adds a third point of stability to the drivetrain...
I wouldnt do it.
AdderMk2 is offline
Old 04-01-2008, 06:11 PM
OnyxCobra
OnyxCobra's Avatar
Rear main seals are cheap, while your tranny is out and everything why not just install a new one instead of messing with silicone, I can't see that working well at all.
OnyxCobra is offline
Old 04-01-2008, 06:17 PM
1985stang
1985stang's Avatar
ORIGINAL: OnyxCobra
exactly what i was thinking. you already have the hardest part done(taking out tranny), just go ahead and replace the seal.
1985stang is offline
Old 04-01-2008, 08:17 PM
94StinkinLincoln
94StinkinLincoln's Avatar
silicone wont seal it completly, it spins real fast, it will leak eventually. get a new rear main seal.
94StinkinLincoln is offline
Old 04-01-2008, 09:24 PM
cleanfitty
cleanfitty's Avatar
Your fan will hit the shroud, So don't start it. Replace the RM
cleanfitty is offline
Quick Reply: Can I run my engine w/ the tranny out?
