Trans problem
Trans problem
I got everythign ready be driven BUT i cant seem to get it to move at at. I have tried all the gears nothing is working what could it be I drove the car the trans and motor came out of it worked great and now i cant seem to get it to move. Help quick i am needing to move it soon
RE: Trans problem
its a c4 and it had a shift kit put in. it ran after that but now it doesnt even sound like it wants to go into gear. how more quarts will it take for a c4 because a lot of it came the tail end when installing it. and how many for the toque converter because i pulled it out and it leaked a little bit
RE: Trans problem
Folk's not setting the converter all the way in is an easy mistake to make. Are you positive your linkage is hooked up right. Have someone get under car while you shift the gears to make sure.
