351? or rebuild?
Old 04-02-2008, 11:41 PM
twcblackhand6970
twcblackhand6970's Avatar
Default 351? or rebuild?
My mechanic has a 351 short block with TRW (something like that) pistons plus a cam with 226 duration. He wants 800 for it. And he'll throw in a GT-40 intake for 400. Should I take the engine w/ or w/o the intake and get a better intake or should I just rebuild my stock 5.0. Which would be cheaper and would give me best life.
twcblackhand6970 is offline
Old 04-02-2008, 11:51 PM
chazmcgee
chazmcgee's Avatar
Default RE: 351? or rebuild?
i think 351 would be better bang for buck.
i don't know much between 5.0s and 5.8's? but from what i here thats where the party's at
chazmcgee is offline
Old 04-03-2008, 12:26 AM
PJC Racing
PJC Racing's Avatar
Cheaper: stick with the 8.2" deck (302), If you go with the 351 (9.5" deck)there are other things you are going to have to buy to get it to fit in the car (exhaust, oil pan, flywheel- 28oz) It's not a drop in. Here's another thing, a properly built 347 (8.2" deck) will open a can of woop a$$ on a stock stroke 351 with the same parts.
PJC Racing is offline
Old 04-03-2008, 01:34 AM
twcblackhand6970
Well, I can get block for 800 and rest stuff for like 1000 maybe, wouldn't 1600 be cheaper than the cost of stroking the old block?
Old 04-03-2008, 06:58 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
go 351!! no replacement for displacement..sure it'll cost a few beans for the extra stuff..but the power will be worth it over a 302...and the gt-40 intake?? if it's for a 302 it won't work on the 351
mjr46 is offline
Old 04-03-2008, 07:16 AM
officer4c13
officer4c13's Avatar
ORIGINAL: PJC Racing
this is true but if you go with the 351 and all that it takes to put it in now andif you ever want to go with a strocker you can do it to the 351 and really open a can of woop *** on any 347.
officer4c13 is offline
Old 04-03-2008, 09:51 AM
WhiteWindsor
WhiteWindsor's Avatar
Do you have any head yet?
WhiteWindsor is offline
Old 04-03-2008, 09:56 AM
twcblackhand6970
no heads yet, the intake upper is the gt-40, idk about lower. im not factoring heads into cost because im going to get new heads for 302 if i stick with it, so same cost there regardless. and im buying 24# injectors regardless of 302 or 351. i have another question to add that i forgot, what size fuel pump will i need for 24# injectors? and the cam is 226 duration, is that good?
Old 04-03-2008, 10:10 AM
cody91mustanglx
cody91mustanglx's Avatar
go with the 351, i spent 2200 on rebuilding my 302
cody91mustanglx is offline
Old 04-03-2008, 10:12 AM
cody91mustanglx
bbk 190 fuel pump or 255
Quick Reply: 351? or rebuild?
