347 power gain?
RE: 347 power gain?
Thanks for the info. I'm trying to map out a plan for a street driven stang I intend to get within a year or so. I'm still playing with h/c/i combos for a 302 in my head. I'd have to probably go with an all new combo after i stroke it (if i do decide to), correct?
RE: 347 power gain?
ORIGINAL: liquidsuspension
^^^^I guess i could be more specific. If i built the combo for the 302, not overdoing it in aticipation of further upgrades, then the h/c/i would be very weak for the 347?
your right on the money man, I know you want to do the 347 now lol.
You see, when you go 347, the valve reliefs on the pistons will allow for most any aftermarket head and a big cam.
Put that on the 302, youll just dog her down.
RE: 347 power gain?
The 347 will require a much different head/cam combo than the 302. They are all interchangeable, but if youuse the heads and induction from the 302,you will choke the 347. I myself have all the bolt on parts together to build my 150,000 mile 302, but when it blows up, I'll have to make a decision to use my existing cam (CI custom cam) on a new 306, or upgradeto a 347 andget a new cam. I imagine if I go 347 my Twisted Wedge heads will work, but I may need to open up the ports.
RE: 347 power gain?
Yeah thats probably about how it'll go for me, due to the flow of funds. I'll have to do the stroker later, most likely. Unless I just happen to run into a good chunk o' change and a decent 4cyl notch. Then I may just build a beast all at once.
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
