sea foam?
sea foam?
my 88 5.0 is running bad like dirty injectors but im not sure. so first ima try this sea foam cleaner nd see if it will fix it. how good does sea foam work? And how safe is it bc i dont want to start having problems with my car
RE: sea foam?
when im around 2 3 or5 rpms it has trouble to go or stay at that rpms nd it back fires in the air cleaner like a loud pop but its not out the exhuast nd i changed the filter nd took out the tank nd cleaned it but still the same problem
RE: sea foam?
you need to make sure that waht you are experiencind isn't a secondary ignition problem, like bad cap and or rotor.....done a tune up lately??like plugs , wires, cap, and rotor??
RE: sea foam?
ORIGINAL: mjr46
RE: sea foam?
ive been thinking about doing sea foam also.
who has tryed it?
notice any difference?
my car runs fine, but the only cleaner ive ran through it was 44k, that **** isent cheap!
doesent sea foam clean EVERYTHING though? like valves, and exhaust ports too?
idk how it works at all, and ive always been scared to just do it
who has tryed it?
RE: sea foam?
ORIGINAL: 302army187
who has tryed it?
who has tryed it?
