help..idle problems
help..idle problems
my idle is getting very low and rough, and when it gets low the voltage gets low too?! i dont know whats wrong....and when i turn on my heater or a/c i find that the voltage drop and so does the idle? is that normal.. if i turn the heat on, my idle can go VERY low and verrrry rough, sounds like a monster cam...this is bugging me, i have noticed it ever since i removed my air silencer.. what is around there that i could of messed up? i looked for loose connections only thing which wsnt plugged in is a plug hanging in the fender but i think its for if i had foglights maybe? cuz theres one on the other side too.. so thatss not it.. please help!!!
i noticed that the wire that goes to my 02 sensors was touching the header a bit and melted some maybe just barrrrely through the casing of the wire.. this would do it would it? would i of gotten a vacuum leak somewhere? but that wouldnt change voltage...would it? maybe my IAC? im so confused
RE: jelp :( problems..
my father said a while ago hes getting a new IAC for it bcuz carb cleaner didnt do it.. but it wasnt doing this before.. just when u start it u gotta give it some rev for a second to it doesnt stall. did my iac get worse?
