auto adjusting rockers???
Old 04-11-2008, 11:24 AM
tucstang85
tucstang85's Avatar
Default auto adjusting rockers???
i have the bolt mount stock style rockers i belive now do i have to tighten these down in any order or way ive been told just go through and tighten them all down to 24 lbs....is this true .....that seems to easy
tucstang85 is offline
Old 04-11-2008, 12:16 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: auto adjusting rockers???
if they are the stamped steel factory pedastal mount rockers just tighten them down to just that....the cam is hydraulic roller to hydraulic pressure compensates for lash.....the only time it matters to set preload is when switching to a roller rocker set up..if all your stuff is stock you'll be fine
mjr46 is offline
Old 04-11-2008, 12:22 PM
tucstang85
tucstang85's Avatar
and again i thank you...having the bolt holding them down with a square type washer thing.....does that sound stock
Old 04-11-2008, 01:43 PM
67mustang302
67mustang302's Avatar
It should be a steel channel that looks like a long metal "u" on the bottom under the pedestals to keep them from rotating. Is that what you're talkinga bout?
67mustang302 is offline
Old 04-11-2008, 02:06 PM
tucstang85
tucstang85's Avatar
http://www.autozone.com/R,APP1349851...ductDetail.htm
the ones i have are identical to these ones
Old 04-11-2008, 02:40 PM
mjr46
mjr46's Avatar
yes those are stock^^^
mjr46 is offline
Old 04-11-2008, 03:14 PM
tucstang85
tucstang85's Avatar
damn that seem too easy....ill do it tonight thanks
Old 04-11-2008, 03:44 PM
5spd GT
5spd GT's Avatar
They need to be tightened down on the base circle of the camshaft. You cannot just pop the valve cover off and start torqueing.
When the exhaust lifter is just starting to move up, the intake lifter is on the base circle, so then torque the intake side.
When the intake lifter is almost closed (that you just adjusted), the exhaust lifter is on the base circle, so then torque the exhaust side.
5spd GT is offline
Old 04-11-2008, 04:00 PM
tucstang85
tucstang85's Avatar
see now im confused im told all different things how do you tell when ones open i cant tell the differnce when i bump my engine
Old 04-11-2008, 04:04 PM
5spd GT
5spd GT's Avatar
I "bump" my engine with a ratchet (spark plugs out), and slowly spend the engine over clockwise.
If you have the intake off, it is super easy. You can see the lifter rise and fall. It is when it quits falling, and rides on the base circle, in which you torque it down.
If you have intake still on, you can just use the pushrods to simulate watching the lifters. You have to pay attention. Removing the intake would be much better, IF you have not did it before.
The base circle on the camshaft is the point of no lift.
5spd GT is offline
Quick Reply: auto adjusting rockers???
