Little AC help needed
When I turn the AC , there's nothing happening. I checked all the fuses and they look good. Is there somewhere else I need to look? Any ideas? It was working before. The only thing I've changed since last tryin the AC was a new CD Player.
RE: Little AC help needed
Hmmmm....Ok, just so that I'm 100% clear on what you're saying...when I turn the AC Switch to MAX AC / Normal AC and absolutely NOTHING happens (no air blows or anything), it could be that the Freon Charge is low? So just get it filled with Freon and it should start blowing?
You need to check to see why the blower is not working. Unplug the blower and check to see if you have power and ground there. Then back track from there. Does anything else electrically not work in the car?
Year of the car and model would be helpful as well.
ORIGINAL: PRO50SC
Where is the blower?
Everything else is working fine in the car.
1991 GT 5 Speed.
