Upper intake Plenum??
Old Apr 16, 2008 | 02:20 PM
Jaked4e's Avatar
Jaked4e
Default Upper intake Plenum??
Im wondering what difference a newer upper intake plenum would make on a 5.0.
Hp?? Probally a cobra upper. thanks
Old Apr 16, 2008 | 02:24 PM
brentloftis's Avatar
brentloftis
Default RE: Upper intake Plenum??
Not positive but I am pretty sure the Cobra upper would require the lower as well for performance. I think the runners are different.
Old Apr 16, 2008 | 02:47 PM
sultan68's Avatar
sultan68
in any case just an intake with or without the lowerisnt going to yield you much, you need at least heads too
if you're going the cheap route ive heard of people picking up gt40 heads from a junkyard for like 90 dollars
Old Apr 16, 2008 | 03:08 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
do your heads before the intake. the bigest gain ive seen on an intake without heads on a stock application is like 14hp.
plus upper plenum without lower to match would not be a wise decision, you'd have to port match which would cost you more money.
Old Apr 16, 2008 | 05:55 PM
nitrous_bob's Avatar
nitrous_bob
ORIGINAL: FivePointOhh
i did a real gt40 w/ ported lower i don't think i even picked up 5-10 ... just don't need it w/ no heads or power adder...the stocker will support you to about 300 hp
gt40 irons are great heads, more like $300/pair gt40p need special headers and i don't like them as much
the cobras is a gt40 based intake, the real gt40 is tubular aluminum...cobra is cast/mass produced gt40, and explorer is the same as cobra but no egr spacer as part of the casting.
anyways... the stocker and gt40's will not bolt up together...in fact NO UPPER WILL BOLT TO THE STOCK 5.0 LOWER.
if you find a good deal...by all means snag it and sit on it, i would do a tubular gt40 just for the looks and do the heads later...but bottom line is...get the heads or a power adder assoon as possible. and if by chance you don't have good gears yet...do them right away and snag up a pair of cheater slicks... traction will make you feel like you picked up 50-80 hp alone.
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
Dokilar
15
Oct 16, 2015 08:13 PM
UrS4
Oct 3, 2015 06:23 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
