idle waiving on 5.0 aod
on my girlfriends 87 5.0 with an aod (bone stockexcept air silencer removed) when in gear the cars idle moves somewhere between 50 and 100 rpm (idling round 750and 850 in gear, 950-1000 in park), i just cleaned the throttle body and iac because it was stalling in gear and just replaced the fuel filter to be safe, whats causing this, any help is useful
also her valve covers leak, its the passenger side of the car, is it possible to replace them with the intake still on or will i have to remove the tb and upper intake, any special tools needed? i imagine i should do both gaskets?
RE: idle waiving on 5.0 aod
whats an easy teller that the fuel pump isnt working great,
and im not sure if you call it idle hunting, its only i minor waiver, needle only moves a bit up and down and under throttle moving its fine
The fuel pump is either working or its not. if you can hear it run all the time (humming noise)that means it is about to leave you stranded some where. The motor is going to rev a little higher in park because it is not being pulled down by the converter. As far as the needle moving 50-100 rpm in gear,I don't know.
Matt's 95 Stang
10-05-2015 07:16 AM
