heads vs. cam, 1.7RR, intake...
RE: heads vs. cam, 1.7RR, intake...
ORIGINAL: 90Mustangfan
Im going to have about 800 or so bucks to spend on mods. I cant decide between putting a E cam, 1.7RR and performer intake manifold....Or get a pair of used heads with the stock cam and stock manifold. Which would make more power. I cant get both at the same time. so If I get heads ill have to wait to save more money. So which yields more power E cam, 1.7RR, performer intake manifold....or A pair old good used heads?
I was leaning toward getting the cam, intake and rocker arms.Then get heads later down the road. How much gain should I expect from E cam, performer intake manifold and 1.7RR's?
i think it would be very wasteful for you to buy 1.7RR for stock heads unless you never plan on buying a set of aftermarkets. i say buy the heads, save up some more money and get a manifold on ebay and youll be much happier in the long run than keeping the stockers.
Ok, with the combintaion of my mods now 4.10's, 70mmtb, CAI, MAF. Pulleys. Headers, H-pipe, Mufflers. Theres not much left to do but Heads, cam, intake. I have plenty of low end from the 4.10's. So If I Get a Edlebrock performer(1500-5500), with the E303(1500-5500), and 1.7 RRs, new lifter and pushrods. Then do heads later. How much hp will I pick up from that?Im getting all the stuff really cheap. Lifter are $120(new), 1.7RR are $150(new), E303 $100(new). Performer intake. $300(used). how much Hp will I gain from that combintaion?
do you want to cut corners or do it right?? why waste your time with used
heads that aren't gonna give you that much of a difference in
power. you have 800 bucks right now. save 600$ more and buy a brand new
set of airflow research heads. 165cc or 185cc they come cnc ported
your gonna need a good set up 1.6 roller rockers and hardend
push rods. those add ons wil be at least 350$ then gaskets 50$ can
you save or get another 1000$. then from there move up to 24 lbs
injectors,then get a intake because you will need it. just a thought
the boy has a small budget....you can buy new alum x- heads for 699 flow real well...some people have to scrap and save for mods..maybe you haven't..there are other good heads out there as good or better than AFR'S!!!!
here ya go
84 LTD LX
None
GT40Y heads, Cobra 1.7 rockers, TFS #1 cam...
Have a never run set of GT40Y heads that were takeoffs and were $699 from buyfordmotersport.com. I also have a used TFS #1 cam in great shape( unsure of milage, but was bought new by me from Summit) and a set of never used, bolted down only Cobra 1.7 roller rockers with an unused rocker shim kit.
$675 shipped UPS for the heads
$100 shipped for the cam
$150 for the rockers and needed 1/4 Allen bit for a 3/8 drive ratchet to install. SK brand, lifetime warranty and was $6 for the socket.
Buy the heads/rockers for $825 shipped and I'll toss in the cam for FREE!
I will do COD for an extra $10, if you have positive feedback somewere.
The reason for selling is they will not match the 347 stroker I am building
__________________
FluidMechanics........
Dailey driver; 1986 LX coupe, 302 HO longblock, Motorsport intake, Edelbrock 600 carb, MSD 6AL, Blaster 2F coil, poly engine/trans mounts, Fluidyne radiator, flex fan, MAC 1 5/8 shorties, MAC H-pipe, MAC 2 1/2 cat back, T5 trans, Pro 5.0 and 3.73 gears.
Building: a Fox Chassis '84 LTD LX with 357ci, also have a 347 shortblock riding an engine stand...
84 LTD LX
None
__________________
