studs on motor
Old Apr 28, 2008 | 07:54 PM
NYMustang50's Avatar
NYMustang50
Default studs on motor
Alright well I came to the conclusion that my motor I just pulled from my new stang that was sitting for like 8 years is no joke. Has anyone ever or heard of anyone putting 1/2 head studs on a 302. Because right now I don't think it is a 302 anymore lol. Anyway is there a way to tell the 302 and 351s apart? Because I know 351s you can put 1/2 head studs on like no problem but on a 302 you would have to do some machine work..
Old Apr 28, 2008 | 07:55 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: studs on motor
get the casting number off the block
Old Apr 28, 2008 | 08:01 PM
NYMustang50
This is going to sound stupid but where are they located.
89Ford's Avatar
89Ford
what intake was on it? measure the valley
Old Apr 28, 2008 | 08:03 PM
NYMustang50
no idea what intake was on it. its a efi intake with i think trickflow heads on it its not an original motor combo of things.
Old Apr 28, 2008 | 08:33 PM
mjr46's Avatar
mjr46
on the block by the starter at the back by the dowl pin on passanger side
Old Apr 28, 2008 | 09:03 PM
ACE's Avatar
ACE
ORIGINAL: mjr46
HOLY CRAP! First post I ever seen you make without a face in it! haha!
But seriously, measure your space between the heads and you will know right away if you got yourself a windsor.
Unless someone put a set of older windsor heads on your block which is a common head swap like I did.
Old Apr 28, 2008 | 10:32 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
measure the borexstroke?
get some measuring take or a ruler, turn the engine until one cylinder is at top dead center, and the opposite should be at bottom.
i think 302s have a 4 inch bore and a 3 inch stroke, and 351s have a larger bore, not sure about stroke, seems like an easy way to find out if you cant find the casting number
Old Apr 28, 2008 | 10:35 PM
89Ford's Avatar
89Ford
ORIGINAL: FuzzyDiceRule
302 and 351w share the same bore size, different deck height-means longer stroke and wider valley
Old Apr 29, 2008 | 04:50 AM
9 Sec 93 LX's Avatar
9 Sec 93 LX
ORIGINAL: nymustang50
302 has 3" stroke, 351 has a 3 1/2" stroke.
302 has an 8.2" deckheight( distance from crank centerline to top of deck) 351 has a 9.5" deckheight.
351w also has a larger main bearing diameter (3" versus 2.75" for the 302).
The only 302 with 1/2" head bolts(stock) are 4 bolt main blocks. (A4, R302,Boss, ETC.)
Hope that clears everything up.
BTW I almost forgot.
Head studs make it extremely difficult/Virtually impossible to service/ remove heads with the motor still in the car!
Use ARP BOLTS instead, will hold four digit power w/ ease.
