Did i float a valve?
Old May 1, 2008 | 08:20 AM
  #21
TrAb's Avatar
TrAb
Default RE: Did i float a valve?
Alright i havent had a chance to look at the cam yet but i will when i get off work today. But i need to go ahead and get me some lifters ordered. What kind should i go with? The ones in it are probably the ford racing ones which happen to be cheap as hell. MAYBE thats why it failed? What kind of lifters would you guys suggest me getting?
Old May 1, 2008 | 08:52 AM
  #22
HACKGT350's Avatar
HACKGT350
how does the dog bone just disapear? its too big to find its way down to the oil plan it should be someone in the lifter valley
Old May 1, 2008 | 08:58 AM
  #23
TrAb's Avatar
TrAb
Im going to look better tonight, i didnt take the lifter bracket off completly last night so i will and get me a magnet and go threw there... But just to make sure we are talking about the same thing im talking about the C looking clip that goes in the end of the lifter and holds everything in.
Old May 1, 2008 | 11:50 AM
  #24
TrAb's Avatar
TrAb
I just found out there is a mustang shop right across the street from were i work , i stopped by and the guy said i have the stock lifters in it and they dont usually fail yada yada yada. So he sold me a used one for $10 bucks...
Old May 1, 2008 | 10:21 PM
  #25
TrAb's Avatar
TrAb
Aight guys i got it in tonight, everything went pretty smoothly... I go to reset the timing, now car wont start. Mainly backfiring out of the carb so im pretty sure its the timing thats off, only thing i dont get is that im following the ford manual to a T. Set at TDC, and aligning the rotor cap were the pin is going to strike the first cylinder plug first. Im pretty sure that i have it correct because when i do this it aligns with some marks the previous owner made on the cap. What could be wrong?
Old May 2, 2008 | 03:30 PM
  #26
PJC Racing's Avatar
PJC Racing
You still need to do the compression check to see if you have valve leakage due to a bent valve.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
LiquidDrink
Sep 29, 2015 10:06 AM
TfcCDR
Sep 14, 2015 12:08 PM
