c&l maf question
RE: c&l maf question
To be honest--- when my car got built we put a C&L on mine and it ran like shiznit as well w/ my 30lbhr injectors... and we couldn;t figure it out..... SOOOOOO... we just used a Pro-M--- more expensive and yeah, pretty flashy, but F'it..... it worked...
ORIGINAL: AdderMk2
or he could look at the color of the mark on the end of the tube
The reason I accumulated the diameter info, was because the 'color coding' from C&L is unreliable at best.
Sometimes NEW meters aren't color coded. Some sample tubes have been found to be color coded WRONG.
Even if he did have the color code there, I still would have recommended he measure the tube to verify...
my dad forgot his caliper..now heres another question i have this maf sensor in my 73 mm housing now( F2VF-12B579-A1A)..would i be better off with the F1ZF sensor in my housing now??im running the a9l ecu..thanks
I'm running a F4S?-???? in my 88 with a A9L ecm in a Cobra 70MM housing that I got off of Ebay. No problems. I ran the E9Z in the 55mm stocker.
Use the F1ZF sensor in the C&L, but it sounds like you have the wrong sample tube.
ORIGINAL: 89mustangfive0
...would i be better off with the F1ZF sensor in my housing now??im running the a9l ecu..thanks
Use the F1ZF...
If there is a problem in the setup/calibration, then it is in the sample tube...
It isn't that the F1ZF is better than the F2VF...
With C&L meters you need to use the same sensor that was originally used with your ecu. If you don't use the same sensor, then the C&L 'calibration' page is useless...
The A9L cars originally used the F1ZF sensor, so that is what you need to use...
Hope that makes sense,
