complete rebuild..stroker kit or not?and best and cheapest palce to order from
#21
RE: complete rebuild..stroker kit or not?and best and cheapest palce to order from
well thats my reason the wrist pin issue. my motors most likely built. after getting my old flywheel resufaced and a t5 with gears put in and all the drama i found out my flywheel is balance to my motor. so im going to geuss my motor is built. its faster than any stock 5.0 i had driven to this point. and my low comp when away with oil, meaning my valves leak.so i think im goint to get new heads and call it done with this car. and move on to a new fox to beat on. this one is my favorite and i really dont wanna drive it all the time, or race it. so i need a track car.but i can get blocks for cheap outa lincolns and the vert needs a new motor, so theres a buildable core there. im just not wanting to mess with this one. im 140psi all the way around after squirting oil in the cylinders
ORIGINAL: 94StinkinLincoln
think of it like this...331 is the same bore as 347,
the 302 has 3.00 in stroker, 331 has 3.25 stroke, thats said to be not too hard on the block and reliable, a 347 has 3.4 stroke, how much more can that hurt really?
piston ring and the wrist pin issue, i have a 331, the srp pistons have a oil support rail b/c they intersect...
#22
ORIGINAL: 86GT 93LX
#23
ORIGINAL: 86GT 93LX
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
