Transmission - Will It Work?
Hey I have a 1995 Mustang GT 5.0 I just bought off my aunt and it is an automatic I was wondering if an older model 5-Speed will bolt up to the block and if so what years will bolt up and also what slave cylinder do I need and what pedal and shifter should I use.
RE: Transmission - Will It Work?
ORIGINAL: xx95GT
you would need a pedal assembly and a tranny from a 94-95. older modelshavea different size input shaft.
theres probably more that you need but i cant think of it now.
yep search button is your friend on this one..cuz theres been many many posts on swappin trannys...but he got the main ones..the pedals gotta come from a 94-5...and its easier to get a t5 from a 94-5 cuz then u dont have to change anything..but if you find a fox t5 u can swap input shafts and it will work the same ...and ya..its cable operated not hydralic..
you need a 94-95 tranny and if you use a fox t-5 you need to change the input shaft to a longer one and use the sn-95 bellhousing, also needed will be clutch pedals ect ect.....
ok ive checked around cant find a 94-95 transmission but i know a guy who has quite a few fox body transmissions so what all would i need to get to make this succesful i know my dad cna do all the work he's a mechanic but he is not familiar with the whole mustang transmission specs. and also would the rear end gears be the same or does it need to be changed also? i been searchin for about 2 hours and cant find nething on the subject.
ORIGINAL: xx95GT
