Exhaust Manifold gasket
Old 05-11-2008, 09:16 PM
Foxbodyforever
Foxbodyforever's Avatar
Default Exhaust Manifold gasket
How hard is it to install i new manifold gasket? I'm just worried im going to break a bolt or something and then have to get the cylinder heads drilled out. I'm guessing you can just take out the bolts, pull the old one out and pop a new one in? I'm also considering just swapping the stock manifolds for headers, will just headers make much of a difference power wise and sound wise with the rest of the exhaust being stock? Thanks
Foxbodyforever is offline
Old 05-11-2008, 10:58 PM
94Yellow50
94Yellow50's Avatar
Default RE: Exhaust Manifold gasket
i just replaced mine on my 94 a few weeks ago..and really i was thinkin alot like what u thought before i started..but they all just came right out no problems...and ya i just figured if there out any way might as well upgrade..as for sound difference on stock exhaust..cant comment cuz the rest of my exhaust was already different when i put them on..but it did change my tone when im cruising and its a little louded at wot...my advice tho is if you upgrade go withsomething that has a solid flange across the entire four tubes and not a single flange for each tube..that way if you ever have to remove them they wont have any chance of warping..
94Yellow50 is offline
Old 05-11-2008, 11:00 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just move whatever crap outta the way necessary..unbolt header..slide new gasket in and reverse to install
mjr46 is offline
Dathan
10-05-2015 05:52 AM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
MacSerio
09-27-2015 01:05 PM
09-24-2015 09:18 PM
Quick Reply: Exhaust Manifold gasket
