no start after changing computer and wiring harness
RE: no start after changing computer and wiring harness
well the computer is good i found out what it is i just dont know how to fix it on the diver side there is 2 plugs one plugs in off the new wireing harness and the thothe i dont event have a plug for it so i was messin with it and jumped some wires and got the car to start any ideas need help
The new harness you put in probably has just one brown plug correct? The harness coming out of the drivers side firewall has a black and grey plug right? If this is the case you need to get a dash harness out of a 91-93 5.0, it will have just the one brown plug and you should be all set.
yea it dose if i use the mass air computer and the sd wiring harness and take out the wiring for the mass air meter and wire it up would that work if so how would i do it cause i know that is what u do withthe mass air conversion kits that u buy
i got it if any1 wants to do a mass air swap cheap mine cost me 80 bucks
http://www.corral.net/tech/powerplant/maf_tech_2.html
http://www.stangnet.com/tech/maf/massairconversion.html
