hp rating(changed therad
#21
RE: hp rating(changed therad
http://store.summitracing.com/partde...5&autoview=sku
and
shuld do the job because this is what ive ben thinking of putting in
(limited slip)
and
(limited slip)
#22
all the rear parts you listed are fine and will work and the driveshaft will work..as for the tremec t-56 it is not a direct swap into a fox and will require modifications if you have a fox.. you want either the 355o or the tko500 or 600
#25
#26
#27
summit has them too see!!
http://store.summitracing.com/partde...p;autoview=sku
