Not really. If you have a decent build that makes say 500-525hp at the flywheel, and assume a BSFC of around .47(decent n/a tune) running 8 injectors at an 80% duty cycle it comes out to around 38-40lbs. It's going to depend on your engine build and tune as to what size injector you need. Also keep in mind that if you plan to run a dry nitrous setup you're going to need more injector.
