MAF/TPS
RE: MAF/TPS
dont need bigger tb or maf, just need to know is if a bad Mass Air Flow being bad, could be cause the Throttle Position Sensor to be off and throw a code? my stroker was carb set up.
RE: MAF/TPS
Suggestions:
1. Clear codes again.
2. Make sure there are no contact problems with both TPS and MAF sensor connectors.
3. Rerun a KOEO self test to confirm codes were cleared.
4. Test drive it for 5-10 min. (check if CEL indicator turns on while test driving it)
5. Rerun KOEO and KOER self tests and LUK.
