Aod problem
Aod problem
I've got a 1988 5.0 w/an aod. When you try to start the car in park it would act like the motor was seized. When I put the trans in neutral the car would start and run fine. If I shifted into reverse or first the trans would stall the motor. When I got the trans pulled apart, I found the pump thrust washer completely melted. Has anyone run into this type of problem before? Any help would be appreciated.
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
