Electric Fan Set Up
RE: Electric Fan Set Up
for the 12v key on source us the red wire on the front harness of your wiper motor, splice it and soder it. this is illustrated by the red line.
yellow line illustrates 12v constant
blue line illlustrated fan power/ground (you'll have two seperate wires)
green line illusrated my adj. probe into the rad
the pink line illustrateds from the transformer thin to the adj therm probe controler.
there will be a ground for your transforer and the fan, i used the grounds located on teh rad supposed by right above the headlights.
okay this is how i want to do it...
i have the probe in teh thermostat housing...
i have the fuse block thing right near my intake box... im going to run the 12v key on wire to the wiper motor wire soder it in there as you said
gonna ground the negative side of the fan to the ground above the light as you said
i also have a 30 amp inline circuit breaker here... i know one side goes to the Aux and the other side to the start solenoid but whgich side goes where... the wire coming fromt he fuse block thingy.. goes to the aux side or the BTR side of the breaker? also the breaker gets put on the starter solenoid on the side with the positive battery cable right?
are you talking about yoru power contant wire?? if you are using power constant wire i like my distribution block on my battery cable....but if you bound to use the starter solonoid it goes to the left post(postive battery cable)
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
