summit o/r x just won't fit
ORIGINAL: OnyxCobra
so what exactly are you having trouble with?
Well Summit has great customer service, I'm sure if you notified them of the problem they would either refund your money or exchange the pipe for another one. Usually Summit puts their name on quality products.
summit will refund but i have summit x pipe and it worked out perfectly. not sure what the issue is, maybe they missed it just before quality control check, every once in a while one sneaks through. but also the bbk and summit pipes are the same, same jigs are used to weld them up.
ORIGINAL: telsonman
i got the summit o/r h pipe, it fit up no problem. hook up the pieces that go to the headers first, then work your way back. thats all I can really tell you. I don't understand how it didn't fit unless they gave you the wrong pipes. I'm running FRPP shorties and no problems.
Called summit and they said no prob. on the return. I think something just got mixed up because it just didn't fit. Got the BBK on the way so I am hoping this will work out and I can get my car on the road again without being open headers
ORIGINAL: mjr46
open headers for the win!! bbk ones fit good.. I've installed a few set before on sn-95's
