5.0 headlight switch cause temp gauge to go through the roof
I have a 92 Convertible 5.0 and everytime i turn off the car and the headlights are left on the headlight switch goes through the roof. Temp is fine and not overheating. Not a headgasket problem. Any body having the same symptoms? I"ve heard to replace the headlight switch.
RE: 5.0 headlight switch cause temp gauge to go through the roof
sounds as if you have a shorted out ground wire. the temp sender wire is a white wire with red stripe(<< i think)that if it grounds fully to something, your gauge will do that. try a manual gauge and see what its actually running at
Should I run a new wire and solder it to the wiring harness to instrument cluster because it would be hell to track that short to ground. it says the sender grounds to the engine and has the Red/white wire going to the instrument cluster A3 pin. If it where shorting to ground wouldn't the temp go down? IF it were being triggered like it is when the illumination of the headlight switch then it would be a short to power causing the temp gauge to go up like it is.
If you leave your headlights on when the car is off, in alot of fox mustangs the tempgauge will rise up, then when you turn them off it will go back down
Seems simple but a bit of a problem if your driving at night like I am and it happens. I"m going to just an autometer gauge. The stock ones are unreliable anyway.
Replace the headlight switch, 30 bucks at most part stores. The other option is to use the switch to activate a relay and have the lights powered directly from the battery rather than running the current through the switch.
