how to adjust throttle cable?
Old Jun 10, 2008 | 08:30 PM
93 LX FiveO's Avatar
93 LX FiveO
Default how to adjust throttle cable?
search isnt workin and i need some help!
thanks
Old Jun 10, 2008 | 08:32 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: how to adjust throttle cable?
adjust it? Be more specific. What's the issue?
Old Jun 10, 2008 | 08:36 PM
93 LX FiveO
if i stab the gas pedal car sputters/hesitates/jerks back and forth
does this for a second, then it will begin to rev as it should.
tps voltage is .98
edit: it is more noticable while under load. it does it in neutral but not nearly as noticable.
Old Jun 10, 2008 | 08:45 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
And why do you think it's the throttle cable causing this?
Old Jun 10, 2008 | 08:51 PM
93 LX FiveO
what do you think it is?
im just doing a "trial and error" diagnosis.
throttle cable came to mind.....
Old Jun 10, 2008 | 09:00 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Could have a flat spot in the tps or maybe the MAF sensor needs cleaning. It def not the cable. Could be the timing is retarded also. Might wanna check that as well.
Old Jun 11, 2008 | 02:23 PM
93 LX FiveO
update:
took the plugs out and they were covered in carbon. is this from running too rich?
also, my valve covers were loose and some of the plugs had oil on them, not sure if its related..
cleaned the plugs, cleaned the maf, cleaned the iac, cleaned the tb. sprayed for vaccum leaks.
car no long hesitates in neutral but still stumbles while in gear. pro you think the clutch cable may need adjustment? it shifts fine and smooth, no noises.. just hesitation.
Old Jun 11, 2008 | 10:38 PM
93 LX FiveO
hmm looks like im on my own. [&:]
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
winner99
Sep 30, 2015 07:04 PM
