?? on a '68 302
?? on a '68 302
hey guys..got a friend whos project is puttin a carb 302 outta his dads old mustang into a 98 ranger....problem is the oil pan is wrong i guess and that the sump on the pan now is in the front..and he needs it to be the type that are on our cars..the deeper in the back...he says someone told him that all hes gotta do is swap the oil pickup from the front to the back on his motor now and then use a foxbody pan...i didnt know if this sounded right of if it would even be possible..so i thought id see what u guys had to say...thanks for the help
RE: ?? on a '68 302
you need a fox rear sump pan, pick upand timing cover cause the dipstick will be in the timing cover on the 68 and you will need to modify pan on fox to accept a dipstick as on a fox block the provision is in the block..soon I will be swapping in a 302 to my bronco II 4x4 which is the same swap for a ranger basically...visit the rangerstation.com for complete details on swap and or james duff.com for swap info and questions.. they have a whole section devoted to this
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
