OOOsss NOOsss
RE: OOOsss NOOsss
ORIGINAL: luckypballer
I broke two water pump bolts when i was removing my water pump. I just wanted to know if i was screwed?
RE: OOOsss NOOsss
ORIGINAL: Tims 88GT
you got it, happend to me[:@]
pretty much got to take the ft. timing cover off, if you drill it out your ok ..
ORIGINAL: hotrodmanII
RE: OOOsss NOOsss
so i need to take the front timing cover off then drill them out?
RE: OOOsss NOOsss
Just use a bolt extractor from Craftsman from Sears. You just drill the center with a certain size bit and wrench the bolt extractor in CCW. Comes out like cake.
Have done many broken bolts.
I would not drill the whole bolt out because if you hit any threads you are going to have to use a tap to get it back to normal. Not fun if you don't have one of those HUGE sets.
