Is a mulit-spark ignition box worth any power?
Old Apr 30, 2005 | 06:50 PM
import slayer's Avatar
import slayer
Default Is a mulit-spark ignition box worth any power?
I'm thinking of buying a multi-spark ignition box to go with my mallory dizzy? Is there any extra power to be had by using one of these?
Old Apr 30, 2005 | 07:19 PM
Chris C's Avatar
Chris C
Default RE: Is a mulit-spark ignition box worth any power?
Not much. The stock ignition is pretty good until forced induction is used. I have seen dynos showing nothing to around 5HP on mostly stock motors. Since you have a 10.7:1 motor it might help some. If you get one go with MSD. Iv had mine on for 8 or so years with no problems out of it.
Old Apr 30, 2005 | 07:56 PM
C/Note's Avatar
C/Note
I ♥ Acer
MAN YOU WILL BE SURPISED ,,,BEFORE MY BOX IT WAS SLUGGAGE..AFTER THE BOX MSD IT WAS CRISP AS A HEAD OF LETTCE
Old May 1, 2005 | 04:25 AM
luckythirteen13's Avatar
luckythirteen13
not sure on the hp but you will defenitely notice a change. the idle gets smoother and throttle response is greatly improved
Old May 1, 2005 | 04:30 AM
GT350Stang's Avatar
GT350Stang
what box would you suggest for a stock block with bored and P&P e7 heads with a edelbrock cam and bbk headers and a 600cfm holley and MSD wires, blaster 2 coil, and the pro bullit dist. on my 84
Old May 1, 2005 | 10:21 AM
stanglx2002's Avatar
stanglx2002
I recommend the 6AL to anybody
Old May 1, 2005 | 11:01 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: stanglx2002
I agree the 6al is a great box, easy to install, has a built in rev limiter and can be used with many of MSD's other ignition componants such as a two step or timing retard.
Old May 1, 2005 | 11:35 AM
Obsol3te's Avatar
Obsol3te
Yup, I went with the 6AL as well.
You'll notice a VERY improved throttle response.
And, it's rev limiter is much better than stock.
Cutting Fuel is never good.
Old May 1, 2005 | 01:11 PM
luckythirteen13
i have the 6al, money well spent
Old May 1, 2005 | 03:18 PM
GT350Stang's Avatar
GT350Stang
do you notice any more accelleration when you instal it at all?
mapitts
May 15, 2016 02:57 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
jaiidutch
Sep 14, 2015 10:29 AM
Wombatnation
Sep 13, 2015 09:16 PM
ryland
Sep 13, 2015 12:35 PM
