buying afr 165
Old 06-18-2008, 06:27 PM
ucjattriskey510
ucjattriskey510's Avatar
Default buying afr 165
im thinkin of purchasing afr 165 today...does anyone know a good place to buy it?? and im thinking of combining this with trickflow street intake... is this a good combo?
ucjattriskey510 is offline
Old 06-18-2008, 06:54 PM
jtmustang
jtmustang's Avatar
Default RE: buying afr 165
with what cam? stock cam?
any other stuff done or thinking of doing with the motor?
jtmustang is offline
Old 06-18-2008, 07:11 PM
ucjattriskey510
yes plannin to leave the stock cam for idle issues.. its a 1995 gt
Old 06-18-2008, 07:19 PM
jtmustang
jtmustang's Avatar
so u are just swapping out the stock heads and stock intake for a good head/intake?
what about throttle body,maf,inj's do u plan on any nos or boost or just want a little more power for your stang?
if yes the street heat would work well for a dd and the heads will get u a nice little bump in horsepower i would throw on some 1.7 roller rockers while your doing it along with a 65 mm throttle body which will make for a much more crisp,responsive throttle response.
Old 06-18-2008, 07:34 PM
ucjattriskey510
is it easy to change roller rockers?? any special tools needed??
Old 06-19-2008, 12:23 AM
jtmustang
jtmustang's Avatar
no special tools needed to change the roller rockers , u also have to decide which kind of setup u want. and if u are buying new rr's i would get the heads with studs. unlike stock which are pedestal the stud mounted rockers are suppose to be a stronger setup with more stability the more rpm's
and to your other question u asked me about the cam change yes u will have to pull the intake ,water pump,timing cover,balancer,alternator,ps,timing chain and gears so if u can i would shell out an extra 200-300 and replace the cam and timing chain and gears
keep us posted and shoot me or others a pm if u have troubles[8D]
Old 06-19-2008, 01:39 AM
ucjattriskey510
alrite, thanks guys.......ill let u know what happensss....
Old 06-19-2008, 02:21 AM
jtmustang
jtmustang's Avatar
oh sorry i just noticed that u have a 95 gt which have the phinickey computers , so i would look into a steeda #19 there are a few sn guys running this cam seems to be a really good cam for the 94 and 95 computers
Old 06-19-2008, 06:14 AM
stang8689
stang8689's Avatar
You can buy AFR heads almost anywhere, Mustangs Unlimited, Brothers, c.j, late model
stang8689 is offline
Old 06-19-2008, 09:33 AM
TrickFlowTech
Banned
TrickFlowTech's Avatar
Just a question, but why are not going with the Twisted Wedge heads?
ORIGINAL: ucjattriskey510
TrickFlowTech is offline
Quick Reply: buying afr 165
