what psi for tires? going to track tonight
#22
RE: WHERE SHOULD I START LAUNCHING AT?
ORIGINAL: grabbem88
ok i'll be taking my car back to the track may 10th..gateway..in illinois.
anyway's i have drag springs,adj. struts/shocks,U/L's,subframes..31 splines....strong enough rearend......
ok last year i fought with her off the line,the best i got was a 13.17@108mph with a 2.05 60ft.....i ended up launching at idle...blah!....i have 275/50/15 bfg drag radial's on it now.
by the way last month she dynoed at 318/329...so where should i launch at?
#23
i just bought some bfg's...
ORIGINAL: hotrodmanII
its all trial and error ,,, just heat tham up good give it 4000 if it dont bog or spin you can go higher ,,, i lauch at 6000 but got dot slicks..get you some ....
ORIGINAL: grabbem88
#25
suspension??...strange 10 way adj..struts/shocks..eibach drag springs/air bag..lakewood upper/lower's...bbk subframes...strange 31 splines 3in studs..eaton/kevlar posi..skinnies up front....there is probably something else..
ORIGINAL: ohsoquik02
true, hopefully he has a suspension if not nothing helps
#28
it's on the to do list...that's why i can't wait for world ford challenge next week!...swap meet...
ORIGINAL: vfast
don't see a drivshaft loop ....
