Change computer
Change computer
Hi, i have a 94 cobra, i have a e303 cam in it i heard i can get my cam to go straight to idle if i change the computer out to a 89 fox computer and a msd ignition, i just wanted to get a little more info on this or maybe someone could help more on this. when i stop, the car will idle high for maybe 5 seconds then finally the idle will drop, if someone could help that would be great was going to do everything at one time getting ready to put different heads on it
thanks
Ron
thanks
Ron
RE: Change computer
I have some idle problems but its come and go witch is prolly mostly computer but ppl do suggest to get your car tuned and have a custom chip burned for it main problem is car keepin running when fan kicks on but also got it where car just sudden bogs down for a second when driving then comes back gonna get my computer done in a couple weeks hopefully that does it
RE: Change computer
and also is your idk if this is what fixed mine but had the same problem where rpms stayed up after i pushed in clutch until i dropped my timing a lil bit and also dropped my idle to about 750 now she drops pretty fast when i put it in neutral
RE: Change computer
i had jpc tune my car but still did it after that i found out about the computer swap a friend of mine told me about it and another dude i know with a 408 did it some im going to try it see what happens im going to get someone to do it because i know nothing about the pins you have to move
RE: Change computer
You are over complicating a problem....... if your setup was "tuned", provided there were no failure codes present, it should have taken care of that problem....... suggest to start with the basics..... run a set of DIY KOEO/KOER/Cylinder Balance Self-Test and check what could be causing the problem.
