Wiring up T5 after AOD-T5 conv.
ok, does anyone know how I can find a T5 harness? I cant find one on ebay....., and i've read around that you can "jump" the park/netural switch from the AOD harness how can I do this? And their is a connection from the clutch pedals that I dont know where it hooks up at? I really need some help, and it is much appriciated thanks alot!!! almost there!
RE: Wiring up T5 after AOD-T5 conv.
you don't need a wire harness just seperate the wires from the prndl switch and run the correct two to the back up lights and the other two join together for start
ORIGINAL: jagman454
could you elaborate on that a little more?, and I have a clip comming from the clutch pedals that I dont know where it hooks up at...
thanks!
thanks!
ORIGINAL: jagman454
wait, if I'm doing a AOD to T5 switch do I even need to hook up the neutral safty switch? i shouldnt have to right?
ChevelleStang
09-09-2007 01:25 PM
