Milled e7te stock heads???
in this months MM&FF's there's a N/A shootout....One guy has a sbf 311 with milled e7te heads with a comp cams stock spec cam T5 and all the suspension goodies and he is running low 11's how is this possible?
RE: Milled e7te stock heads???
its a stock LIFT cam, you can do just about anything TO the heads, including new valvetrain, larger pieces, portwork out the A
if you know how to drive, a gt-40 headed, X cammed notch can run 11's
I know this because my tuner has done it... several times
ORIGINAL: 1mean5.0
I would of never thought you could get that much performance out of a set of E7's
ORIGINAL: 1mean5.0
