Coil Problems
Old May 4, 2005 | 11:11 PM
Dockboy19's Avatar
Dockboy19
Default Coil Problems
Recently bought a 89 Gt, previosuly had a 87 GT. Never had a problem with coils. 89' drove it for 3 days no problems, park it one day go to start it like a hour later and nothing. Go and buy another coil, starts runs for like 20 mins then dies. I am lost with this car. Any help at all would be nice.
Old May 5, 2005 | 12:35 AM
90GTRagtop's Avatar
90GTRagtop
Default RE: Coil Problems
Are you sure the coil is bad? Use an ohm meter or the ohm function on a multimeter and check the resistance on both sides of the coil. I have gotten coils before that didn't last much out of the box, but not ususally. Might also need to check the TFI (Thin Film Ignition) module. Have you tried pulling any codes from the computer with the Key On Engine Off test? Do you have any mods that could be cutting it out? Especially, did someone before you have an alarm system that could be cutting it out?
Old May 5, 2005 | 12:49 AM
GT350Stang's Avatar
GT350Stang
i had the same problem. what mine was doing is that i had the wrong resistance in the coil and so what it was doing is melting the coils together and it would run for like 30 minutes and then die. so i just went and bought a MSD blaster 2 coil and i have not had a problem since
Old May 5, 2005 | 07:41 PM
Dockboy19's Avatar
Dockboy19
I talked to some people and they said it might be the Ignition control module??
Old May 5, 2005 | 07:44 PM
stanglx2002's Avatar
stanglx2002
sounds like the ingition module is getting hot and shutting the car off. The ingition module has to has thermal grease on the back of it or it will get hot and shut the car off
Old May 5, 2005 | 08:02 PM
Pure5.0's Avatar
Pure5.0
Where is the ignition module located at?
Old May 5, 2005 | 08:14 PM
stanglx2002
on the front of the distrubutor
Old May 7, 2005 | 01:46 AM
P.S.I.cho's Avatar
P.S.I.cho
in my 95' there is a sensor in the dist (magneto), when this goes bad u usually have to replace tfi too.
Old May 7, 2005 | 10:33 AM
86HOGT's Avatar
86HOGT
Would a worn out pickup and/or TFI create random misfires, yet still run strong off idle?
Old May 7, 2005 | 11:31 AM
90GTRagtop's Avatar
90GTRagtop
Yes it could, by the very definition of what you said. If it's random, then the odds are that it would happen most often in the normal condition of the motor, which would be under throttle going down the road (most of the time), followed by idle (sitting at lights etc.), and lastly by acceleration or deceleartion periods (least amount of time). All that said, if it's breaking down when it gets hot, it may well perform fine when it's cool.
jma2
Jul 10, 2023 01:00 AM
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
musnicki
Sep 23, 2015 07:11 AM
Wombatnation
Sep 13, 2015 09:16 PM
