Codes?
Old Jul 9, 2008 | 08:58 PM
94GTPRO5.0's Avatar
94GTPRO5.0
Default Codes?
I have a 1994Gt 5-speed, when i run for codes i get Code (311- Thermactor Air System problem- no operation during Engine Run Self-Test BANK#1) and code (314- Thermactor Air System inoperativer during Engine Run Self-Test Bank#2 with dual oxygen sensors)
I have no clue what them mean, could someone help me out? would it make my car not idle and i can't even get a test light to work because when I put the light on the balancer the car idles up and down and can't get a good enough reading to put it in time.
I have no smog or no egr, CAI, 2 1/2" H-Pipe with Flowmaster 44's, also just put new 19lbs injectors on it, new mass air flow and TPS
Old Jul 9, 2008 | 09:21 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Codes?
the thermactor codes are a result of you removing smog = don't worry about those codes ..as for your issue.......have you tried cleaning IAC MOTOR and checking for vaccum leaks?
Old Jul 9, 2008 | 09:28 PM
94GTPRO5.0's Avatar
94GTPRO5.0
Default RE: Codes?
yea i have cleaned the IAC, and cant hear of any vacuum leaks, but have not tryed to really look for any leaks, could the IAC be bad and not throw a code?
I have tryed to adjust the throttle body by turning the idle screw also.
Old Jul 9, 2008 | 09:32 PM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: Codes?
no egr? if so, how is it deleted..
with the idling/timing issue, disconnect the battery for 20 mins
remember to unplug the spout when timing the vehicle, on ur 94 its located near the passenger strut tower.
Old Jul 9, 2008 | 09:36 PM
94GTPRO5.0's Avatar
94GTPRO5.0
Default RE: Codes?
yea, i have already tryed that. Thecar wont idle right ( it wants to surge up and down when trying to idle) and cant get a good reading on the timing gun.
Old Jul 9, 2008 | 09:37 PM
mjr46's Avatar
mjr46
Default RE: Codes?
if you play with the idle screw it will throw the tps off and cause all sorts of erratic issues... so need to perform a base idle reset procedure and set all back to stock....moving the screw is not the proper way to set idle.... this is:
http://www.muscularmustangs.com/idlereset.php
Old Jul 9, 2008 | 10:54 PM
94GTPRO5.0's Avatar
94GTPRO5.0
Default RE: Codes?
Ok thanksI will try that tomorrow and will let you know what happens.
Thanks alot.
I hope it will work.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
