Help! Code 91 on KOER Test
Car is idling great, but on the way home today every time I let off the gas to slow down the car started to buck while in 1st, 2nd, or 3rd gear. I didn'tnotice it happing when going at highway speeds. The car did not hesitate when accelerating or as long as I was giving it gas. When I come to a stop the car idled very smoothly, When I got home ran the KOERtest and got a code 91 (HEGO sensor indicates system lean). I also ran the KOEO test and got a code 11 (system pass). With this info dose anyone know what might cause the car to run lean.It’s a 1990 Mustang GT 5 speed. Only thing done to it isCAI,Hypertech chip, under drive pulleys, 160 degree thermostat, Flowmaster Exhaust, Flow Tech Headers. All of the smog equipment is hooked up still. Also I only run 93 octane in it, Thanks for the help.
I don't think you need a 160 stat...I want to get a tester to run KOER/KOEO, does anyone know what tester I need and maybe a good place to get one...checker, Auto Zone?
ORIGINAL: camaroeater
Having a 160° T-stat does not allow the car to completely warm up to full operating temperatures, and can cause all kinds of stupid problems
I'm going to put 180 degree T-stat in it this weekend hope that will solve this issue.
The only reason I put the 160 degree T-stat in was because that’s what Hypertech recommended to keep the motor from possible detonation and to get the best preformance from the chip. Thanks for the help.
