my 347 Blows oil
RE: my 347 Blows oil
yes, the rings are staggerd and right side up, they are file fit from perfect circle, did everything slowly and propely. a machine shop did the .030 overbore. Yes, the kit is pistons with pin in oil ring lands and a spacer under the oil rings. Yes, I put on 2 PVCbreathers plumbed into vacuum line. Please help, something very wrong. Thanks
leakdown is your next step, not a static compression check, an actual leak down, that will tell you if ring seal is the culprit. Pin in the oil ring is irrelevant, the only time thats an issue is if the knucklehead didnt use the rail spacer, seen it may times, but thats not the case here
Drive some more at normal speeds for a week, and pull the plugs to narrow it down and let us know what you found.
But congratson the build!!!!!,we alllove the stroker packages for the 5.0, makes a true 12 second car.
ORIGINAL: roegster
Thanks for some new ideas, I will try the leak-down test and drive tha car normal for a week. Please keep coming back to this thread down the road.
ok ,I'll make up an oldspark to air adaptor and do leak-down test. This test is very fuzzy to me, it's been several years. Do I put theno. 1cylinder on the compressionstroke TDCso the valves are closed? After I do no.1, I turn the engine over by handtill the rotor points to the next terminal on the cap and so on and so on, right? Thanks
