Manual transmission fluid?
ok i want to change my tranny fluid on my 1988 lx hatch and i was wondering what i should use and how much. i heard royal purple was really good but idk. i have to change it soon and money is not a problem i just want the best tranny fluid to use for my stock t 5
RE: Manual transmission fluid?
i put mobil 1 75w 90 full syntheticgear oil inmine on a fresh rebuild. it sounds like it would be real thick but its not. it poured real quick and easy. if im not mistaken i think it was about 2 and 3/4 quarts. it shift awesome. smooth in any gear. it downshifts great, not notchy or anything. a buddy of mine with a t-5 used amsoil ATF in his and it shifts good too. i would recommend both.
NEVER put gear oil in a t-5 EVER.[&:] the t-5 is designed to use atf, sounds strange to have a manual use auto fluid but thats because of the ports that are inside the case, gear oil is too think and wont move you can only use atf. i use royal purples syncromaxx, it's atf designed for a std tranny
quickstang if you put gear oil in there, flush it NOW! it may work for a short time since you said it was just rebuilt, the new parts are gonna make it feel like it's fine, dont kill your tranny after a fresh rebuild
ORIGINAL: quickstang89
BeatnikFink
10-01-2015 08:00 PM
09-25-2015 06:42 PM
