Hypereutectic?
Hypereutectic?
Ok ive been reading all kinds of reviews and these pistons dont seem half bad. I dont feel like spending an *** ton of cash 500+ on pistons.How good are these i hear claim and ive red in some of these reviews thay can take 500hp? Anyone have any insight on these beasties. Is there a number i can check out and call to maby talk to a tech about these?
RE: Hypereutectic?
i really cant see them handling that much power.
my forged pistons were only 300 some, and if you plan on running any boost or n2o at all you've gotta go forged, they'll tear the hypers apart.
RE: Hypereutectic?
Hypereutectic pistons?...... what is that?.... as you can see, they don't exist as an alternative in my little book. BTW, a good set of forged pistons would be in the low $400 cost wise. HP ratings is not a good way to rate anything..... they could be good for xxx HP, but might not survive some abuse to produce that power under not so optimum circumstances.... BTSTDT.
RE: Hypereutectic?
ORIGINAL: jwog666
i have seen them break when used in circle track applications, forged almost never
RE: Hypereutectic?
id just like to bump my compression which i havent decided on either. Theres so much if i go forged i can bump compression and run n20 i dunno ill look into it maby get a better job.
RE: Hypereutectic?
if you just wanna bump compression via a piston kieth black makes a .200 dome piston for 250.00... I have a set I used in a 306 and with aluminum heads compression was close to 11 to 1 and it ran like a bat out of you know what!!
