fuel filter location
Old Jul 19, 2008 | 10:06 PM
zippo2341's Avatar
zippo2341
Default fuel filter location
does anyone know where the fuel filter location is on a 95 GT?
Old Jul 19, 2008 | 10:22 PM
ewgoetz's Avatar
ewgoetz
Default RE: fuel filter location
Right above the Rear axle in the middle under the car.
Old Jul 19, 2008 | 10:25 PM
Joel5.0's Avatar
Joel5.0
Yep......
Old Jul 20, 2008 | 01:36 PM
zippo2341's Avatar
zippo2341
and to remove it do i just clamp both ends of the hose off, swap the new filter in, then reattach the hoses, or is their a certain way to do it?
Old Jul 20, 2008 | 01:41 PM
945LSTANG's Avatar
945LSTANG
ORIGINAL: Joel5.0
Yep......
can you see those white plastic things on the end of the line? pull those out and the line should pull right off.
Old Jul 20, 2008 | 01:44 PM
945LSTANG's Avatar
945LSTANG
my explanation kind of sucked so here.
Old Jul 20, 2008 | 01:52 PM
zippo2341's Avatar
zippo2341
945LSTANGthanks for your answer, after i pull those off will fuel come out? or should i clamp the lines closed first? thanks again
Old Jul 20, 2008 | 01:59 PM
golden_eye's Avatar
golden_eye
You need to relieve the fuel system pressure first. You do this by going in the trunk and popping up the fuel shutoff switch behind the driver side taillight. Crank the engine over a bit to use up whatever is left in the lines. Some fuel will still shoot out though so make sure you are ready for that.
Also, I couldn't seem to get mine off without actually removing the whole braket that it was mounted too as there are little tabs that hold it in place in addition to the metal strap you can see in the pic above.
Projectquick's Avatar
Projectquick
A little gas will come out but the fuel lines are metal, if you clamp them shut goog luck getting them to fit on the new filter. Just make sure not to get gas in your eyes and you're good.
Old Jul 20, 2008 | 02:49 PM
945LSTANG's Avatar
945LSTANG
ORIGINAL: zippo2341
just plug up the lines with an old rag.
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
