i just bought a 6psi supercharger and want to know what size injectors i should get. i have a 306, shorties, 2200 converter, shift kit, pullies, and other minor bolt ons.
with only 6 psi I believe those kits are designed for stock injectors..but it all depends on how stock your motor is now???? 306 with what internals??? = h/c/i???
after the supercharger i just plan on changing the upper manifold and maybe put in a big cam. thats it for sure. the internals are stock except for the heads and i got crane cam rocker arms 1.6.....that supercharger should give me about 70hp right? i will probably be making with the juice 420.
's will be fine for 6psi but if you decide to up the boost, (which I'm sure you will at some point) they will fall short. I ran 30's at first, but they weren't enough.
