Cooling Problems
RE: Cooling Problems
ORIGINAL: foxstang11
Well, I don't think the water/coolant mix would make me overheat 40 degrees, and the radiator is brand new.
ORIGINAL: redtxlx
wouldnt you notice poor idle quality if the head gaskets were bad?
Okay guys, so I put the new waterpump in and that did not fix the problem. What I did notice was the thermostat did not open until almost 210 degrees at an idle. I'm told to take out the thermostat, but if that doesn't work, what may be the problem?
Well, I have an 18 " electric fan on the radiator and it works properly. The original clutch fan did nothing to cool the car. And I know many people that run their EFI mustang's w/o a thermostat.
My main issue is that I see no flow through the radiator until it hits over 200 degrees, I also don't understand how the car ran hotter once I put in a bigger and better aluminum radiator? If you can answer that question with a sensible reason then be my guest.
Sounds like an air bubble to me, or your coolants holes in the block are clogged up. I have a c4 in my car, and ran it with EFI about 3 months and it did get hotter than with the T5 but nothing outrageous. And that was with a Summit racing aluminum radiator and a stock clutch fan. Just did a carb swap and it doesnt go above 190 now....gotta love it
