computer
if its a mass air flow car, get a mass air flow sensorthats calibrated for the injectors you want to run.if its speed density iveHEARD(dont take my word)you can run 24's with stock computer but i dont know
ORIGINAL: Milton
if you just throw 24# injectors in a SD system, the values in the VE tables will be SO completely wrong, that the car (most of the time) wont even start
sorry I have a 91 mustang 5.0 bored .30 over with alm. heads trick flow stage 2 cam trick flow intake. for the injection system 80 mm mass off a lincoln cold air intake 70 mm bby throttle body bbk fule pressure regulator set at 50 psi 19 lb injectors. to run 24 lb injectors can I change the computer to a cobra or any other computer or is it best to buy a chip I dont want to buy a new mass air because I have the 80 mm but its set for 19 lb injectors. if I need a chip what is the best one. or what is the best computer
