ARP head stud questions
hey, i got ARP head studs for my car, and the setup came with the studs, bolts, and these weird peices that look like washers, but have a ring going around perpindicular to it, its hard to explain, but yeah, it fits around the studs, and i dont know where it goes, and the instructions arent helping
put the studs in, put ur gasket on the studs, then put ur heads on over teh studs. then put the washers over the studs into the holes in the head. the small rim goes into the head. then put the nut on and dont forget to use the ARP lube
the kit didnt come with washers, it came with the things i described, when you look at it from the side, its shaped like a T, and its the washer, and on the inside, a ring about half an inch wide around the inside perimeter, and it doesnt go into the head
like i said it came with bolts and these..... ill ask my buddy david, hes our mechanic
wait a minute!!! I have the 185's which are theroretically 351 heads and use the spacer/bushing so they can be used on a 302 with 7/16 head bolts.....you have 165's which are 302 heads I believe and may not need those bushings...see how much wiggle room the head studs have???..if hardly any..you won't need them
none, and the holes are too small anyway, as in, on the inside of the bushings, i can see the outside of the hole
so i dont need them? what about washers?
