adjusting valve lash
i guess the search is still broken on the site? anyway im wondering what valves you can adjust at the same time with a 351 w..as far as i know they are the same firing order as a 5.0 ho correct?
RE: adjusting valve lash
yes......I like the tdc methood over the split overlap methood cause you run each cylinder up on tdc and can do both intake and exhaust at same time on that cylinder
