need ac help
RE: need ac help
i think the conversion kit is $30-40 somthng like that, all you got to do is recover the freon and no not in the air that is a major fine, vac the system down, put on the conversion kit recharge with 134 and oil, check for leaks and thats it.
RE: need ac help
om im being retarded about it!? lol wtf i just asked a qustion. and i didn't reply yet and im being retarded about it ok buddy. any way i thought it was hareder thin that some one told me i had to replace every thing to new stuff ill have to look it up thanks.
RE: need ac help
The kits usually come with the fittings,oil, and the freon.
I wouldn't use air or anything like that.You may have a big leak and hear it while you start filling.Or you could have a small leak that takes a week to leak out.
Best thing to do is to charge it and see what happens.
If you really want to check it good buy a can of the dye you can install and put it in as well.Then if it stops blowing cool you can use a black light with yellow glasses and see where it is leaking from.
