Valvetrain Noise . Indication to problem? Normal? Do i need new rockers?
Hey All. id like everyones expert advice here. even if you think it doesnt make sense ust tell mewhat you think.
Ok heres thescope. I am getting ASLOT fo valvetrain noise throughout entire RPM range. To my ear it sound sliek roller rocker noise. as if it it tapping on the top of the valve, but it could as easily be the pushrods rattling into the rocker then the lifter. its a steady tapping at idle and it rattles up and down as i rev. its a 347 stroker with 1.6 rockers, comp cams cam pusrohds and doubled up springs. i got a lift of .575 .565. comp cam performer 282. Aluminum rockers, full roller fulcrums. are my vavles too short? can the rockers be loose, coudl my pushrods be short. combination of all? Can my timing be off and I am hearing timing issue?
RE: Valvetrain Noise . Indication to problem? Normal? Do i need new rockers?
Yes I did remove them and no there were not any loose or broken rockers. pusrods were loose only a tiny bit during one of the phase and only enough to turn it by hand slightly.
having a loose pushrod can cause a slap/tick noise as far as i understand. is that what you're hearing? did you try the TDC method for setting your rockers?
to be TOTALLY honest. I am very unfamiliar and i didnt do it to the rockers TDC method. Is there a way of doing it correcrtly listed in a step by step online somewhere? other then bad knocking can that cause any future problems on a race motor?
ORIGINAL: mftech
yes i did purchase those pushrods. went in smoothly.
