1985 throttle body replacement
RE: 1985 throttle body replacement
convert the unit to a carb, a nice 650 cfm holley will do the trick...
the 3.8 that used to be in my '86 was CFI... and it was crap...
as far as I know, you'll need a new intake manifold Edelbrock performer dual plane intake will work, the carb and ditch the wiring to the CFI
you really are wasting your time with the cfi crap. you will be much better off swapping over to a carb set up than that stuff. as for parts for it i dont even know if they still sell rebuild stuff for it so you just might have to swap to carb
not everyone has the option and or money or know how to do the conversion so in most cases a rebuild is most practical...to the OP what do you need to rebuilds on the unit and why do you think it needs a rebuild?? what is the problem??
ORIGINAL: mjr46
this car is actully my friends that doesnt have money to spend on a whole carb swap. well we took it to an auto shop and they said there computer was saying that the egr wasnt even working, and that they need to rebuild the throttle body(or what ever that thing is) saying it only burns half the fuel that is put in the motor. so i was thinking of just getting the new unit and egr.
its only burning half the fuel its injecting into the engine? that doesnt mean the tb is bad and how do they know this? did they do a 5 gas analysis on the car to judge how bad it is? burning only half the fuel sounds more of an engine issue itself unless this thing is just dumping way to much fuel in the engine
ORIGINAL: nightcrawler52
alright someone understands me,
ORIGINAL: mjr46
wow. ill try to get the codes from them and figure this out. this shop is called honest auto but they dont seem so honest. they said the distributor cap needed to be replaced but we replaced it before we took it in. they also said the plugs needed to be changed when they have less then 10 miles on them. ahh we need to get that car out of there.
It may not be the fact that they are dishonest..more so that whomever is working on the car doesn't have a clue about theroy and operation of the system so they are just throwing parts at it..and unfortunately it sounds like the wrong parts
